21 - 31 of 31 Posts
hi i have fitted rear light cluster led to my astra the only problem is check brake light is on on the dash but push ok button on steering wheel and it dissapears until you re start the car which is not really an issue as the rear led look much better done this all plug and play so no wires have been cut. Wheel Tire Vehicle registration plate Automotive tail & brake light Vehicle
AdieMcc i paid £150 2 years ago for all the light clusters these have been on the car since oct 2017 and have had no problems except for check brake light when you start car but no big issue.
Crosseyxpower thanks m8 was ok once got my head around it :twisted: i sourced the outer molex 4 pin plugs you need mail and female for outer light clusters and sourced boot lid wiring loom from breakers for the inner light clusters it went ok been on the car since oct 17 and been no problems.
Astra maestro said:
Have you got instructions luders? I wanna also change my rear lights. But no one doesn't know how to fix this. Hope you can help me 😉
There is a solution for this. JRC Vaux works can do this if you are in England but if not they can sent you instructions how to do this.
21 - 31 of 31 Posts
