1 - 20 of 21 Posts
Finally got my Astra 1.4T (150) power red engine start and stop.
Need to remove the intellink so I can install my subwoofer wires at the back of if.
Anyone got a guide on doing this??
Discussion Starter · #6 ·
Was able to get the long passenger side panel off . But now struggling in getting the small panel near to the steering wheel out.
I believe there is 3 clips in that small panel but I found 2 of the but can't find the 3rd one
Found 2 screws so far to remove but can't get access to the 2nd screw because of that small panel
on most modern cars ive had with built in stereos theres a take off point in the boot for connecting amps etc to , not sure on astra as it doesnt have an optional highline stereo but thesedays most amps will take high level inputs from the speakers and its fairly easy to find a switched live i would imagine
Vpatel120 said:
Really I didn't not know that. I know there is an second battery in the boot so there might me some controls there. I'll have a look and update you lots
Second battery? The astra only has 1 battery and it's under the rear seats ;)
Discussion Starter · #10 ·
Ahh right !! Sorry bout that ..
So I was able to get the panel out .
I'll show the photos of it.
And got the two screws out and now I'm totally stuck !
Have no idea what to do next
Hope the images helps you lots and help me in the next stage
Great - well done. Could you post some more photos of the rear and the connections please? Any sign of a rear USB socket or anything else interesting?
Discussion Starter · #15 ·
okay I'm going to try a different technique.
I will try and get access to my rear speaker wires and splice into them to install a line out convertor (with a radio wire) or if not a line out convertor with no radio wire.
Problem with the second way is that i will have to find the wire to the cigarette lighter and splice and connect the radio wire with that cable, so the amp will turn on and off.
Sorry I'm positive battery is in the boot.Lift carpet and it should be on right side just behind the seat I don't want you dismantling the seat.as mine is where Iv said
1 - 20 of 21 Posts
