1 - 7 of 7 Posts
I have the Intelilux light on my Astra K, excellent lights, have it on auto, everything's fine!
There is one thing that it does, which i'm not sure if it is a fault or standard function.
In daylight, I drive under a bridge, not a tunnel, there is a lot of shade for about 30-40 meters.
The lights turn on, all good. When I exit and sunlight hits the sensor, it should turn off the lights, right?
Well, it didn't, so I stopped, turned off the engine, then the car went to daylight mode, no headlights, just the day lights.
Today I tested it again and didn't turn of the engine.
The lights went off around 4-5 minutes after I drove under the bridge.
Could it be a malfunction or is it something standard?
Don't have any other problems with the Intelilux lights, just this one little thing!
I've found a similar issue with auto lights on my K and both my Astra J basically I think the issue is the sensor gets confused ehen going from very dark to very bright.
I had a Insignia following me the other werk both our lights came on together but mine went off before his. So I think its a Vauxhall thing.
Same thing with my current Astra J. When I drive to a tunnel or under a bridge, main lights turn on quickly. But after I exit the tunnel/bridge, it can take 3 to 5 minutes before car switches back to DRLs. I have halogen lights with traditional bulb DRLs. VAG cars seem to work better, they switch instantly to DRLs when it's bright again.
Depends on the level of light at the time.
If it is bright sunshine, lights should go off straight away. If it is a bit grey and overcast and especially if any shadows the lights can and do stay on longer.
This has been the same for every car I have had with auto lights.
Since my partner lives in N London and I live in SE London, I get the joys of travelling through the Blackwall and Dartford tunnels on a regular basis. On each occasion, the 'Intellilux' headlights have responded almost instantly when entering the tunnels, but take a while, in my limited experience, to turn off (at least a minute or two). Not a problem as far as I'm concerned - they're unlikely to dazzle other drivers because of the technology and the power consumption should be minimal!
1 - 7 of 7 Posts
