I usually open all 4 of my windows holding down the unlock button on the key fob, which works no problem.
Today, I was in the car, both driver and front passenger doors were wide open, so I pressed and held the unlock button to open all 4 windows, driver and both rears opened, but front passenger window did not. I thought nothing of it, thinking it will reset itself when car locked. Got home, turned car on, but the front passenger window still not working. I got a message on the dash: 'Open passenger window then close'. Tried this, but window would not open either via the driver master window console or the switch on the passenger door. I do hear a 'clicking' noise when pressing the windown buuton though, as if there is a contact happening in the relay, but nothing else.
I turned off the car, locked it and then pressed and held the key fob again. This time rear windows opened fine, but the driver window 'juddered' and stopped about 1/5 of the way down. Passenger window stayed up. Started car and used the window buttons, driver window works fine, as do rear, but front passenger window still not working.
I tried resetting the windows, by following the instructions from one of the threads on here-disconnect negative terminal on battery for 20 mins, then reconnect and press and hold window button for 10 seconds. Did all this, still no joy. Any help would be much appreciated!!
