1 - 20 of 30 Posts
Hi everyone! Has anyone fitted some led lights for low beam and high beam which fits quite easy and are error free? If so do you have a link for them and could you please explain what are the steps? I know there are plenty posts about leds but couldn鈥檛 find what I was looking for. Thanks in advance!馃
Photograph Digital camera Product Reflex camera Camera
Product Font Gas Engineering Cylinder
I鈥檝e ordered the f2 for the headlight and the other ones for reversing lights as I鈥檓 not seeing much when reversing.I鈥檒l keep the topic open so I鈥檒l update after fitting them to say if I had any error.
Hi everyone! I鈥檝e tried to update my low beams with those f2 h7 headlights, turned out to be quite a tricky job. But in the end I鈥檝e done it( at least that鈥檚 what I thought). Went inside the car to check if they are working, and turned out right low beam, right indicator, and left side daylight not working anymore plus error on the dashboard. So I鈥檝e removed the new led and I鈥檝e put the old halogen back, came inside the car and wasn鈥檛 working anymore. I鈥檓 gonna mention I didn鈥檛 touch the left side lights at all, and I also get check brake light, check right dipped beam. Checked for any damaged cable or something like this but I haven鈥檛 seen anything being wrong鈥 Any idea how can I fix all these without going to a garage, as I鈥檓 a bit broken after all these winter holidays..
Motor vehicle Automotive tire Automotive lighting Hood Wheel
Try disconnecting the battery earth for 20 mins or so,it may just be a case of the bcm getting it's knickers twisted
Discussion Starter · #7 ·
I know the battery is in the boot under the matt, but where is the earthing?
Here,10mm nut
Asphalt Audio equipment Automotive tire Rolling Auto part
Discussion Starter · #11 ·
Earth been removed for 30 minutes, I put it back on and the exact same thing afterwards鈥 can it be a fuse? Even tho both lights are on the same fuse, I don鈥檛 see how one could work and the other one not鈥
when fitting the f2 bulbs,fit them out side the bulb unit check if they work if not turn the bulb 180 degrees try again.the bulb conection fits both ways but one is right
Discussion Starter · #13 ·
I鈥檝e tried that before putting the halogen back in鈥 now multiple lights are acting up and not sure what to do鈥
Discussion Starter · #15 ·
did you reset them on the dash,try a obd reader to see if any codes
On the dashboard I get 鈥 checked right dipped lamp鈥; 鈥渃heck brake lights鈥 and check indicator lights. Not quite sure how can you reset them on the dash鈥
where you scroll through the menus on the dash push the centre button,if that does not work i am sorry i cannot help
Do you have the "dismiss" option in the DIC for each warning ?
if so do the dismiss routine for each one and see if that sorts it
Vehicle Automotive design Personal luxury car Material property Font
It's hard to work out exactly what's gone wrong,is there any chance you've shorted something out when changing the bulbs ?
could you post a list of exactly which bulbs are now not working
Discussion Starter · #20 ·
Front left daylight lamp (the led one that looks like a strip)
Front right indicator
Front right low beam ( the one I was trying to replace)
And out of the brake lights only the middle one above the rear winndow works.
Car Speedometer Vehicle White Tachometer
Car Speedometer White Light Tachometer
Car Speedometer White Automotive design Light
1 - 20 of 30 Posts
