hi stevie , yea i gathered there would be a base model stock , but im not touching it till march for the new plate , plus i should get an extra 400 back from finance settlement for the 2 payments i will make , im happy with the standard sri nav , although in hindsight i might have stuck with power red and added a few extras but will check tmrw if its too late to change it , if not ce la vieStevieBoy said:Hi Guys,
Gunswills standard spec astra sri is probably already built, think they call it pipe stock, hence quick delivery. UKTekkies and mine are factory orders, hence the wait. When car has been ordered you can change spec easily until it has been assigned a build date slot, after that you may not be able to.
Hi StevieBoy,StevieBoy said:Hi Guys,
Thanks for the response! That sounds promising atleast! Hope I get the answer I want from the dealer tomorrow! So your build date was assigned the same day it actually went in to be built?UKtekkie said:
- 31 Dec Ordered
3 Feb build slot allocated
18 March Delivery date (new)
24 March Delivery date (original)
I'm still on step 1 though. Build slot appeared on 3 Feb (ie same day)
Well, step 1 appeared on trackmyvauxhall site on 3 Feb showing:RG90 said:So your build date was assigned the same day it actually went in to be built?
