1 - 15 of 15 Posts
Dear,
have you notice about compatibility of this with previous versions of Astra H-J ?
I've to buy one of this in after market and I have troubles for details ...
My car dealer wrote me that 115/70R16 measure is the same, but are not compatible.
My tire repair specialist told me that Astra H is ok.
I've so many troubles ...
Discussion Starter · #6 ·
My Astra K measures (1.0 petrol) are:
tire 115/70R16
studs/PCD 5x105
wheel 6.5J x 16"
bore 56,6
offset 41
I don't understand: if I found a wheel with this measure, can I buy it without troubles?
My car dealer told me that isn't enough and that new K has special requirments. Which? :?
I wonder if the dealer is talking about how the wheel fits in the boot of the car. There is no wheel well in an Astra K, so the wheel fits under a different false floor in the boot. Maybe the way it holds in place is different too? If you are happy just to have the wheel loose in the boot then that maybe ok?
Discussion Starter · #8 ·
Thanks for your reply.
Usually I prefer to have wheel loose in the boot, in a custom cover; in this way, I may use it only during a long trip and not in the city where I leave it in garage.
So, the main question regards only mounting compatibility, not where holds it when not in use.
But, after 3 weeks, I'm not able to know what i have to buy.
Frustrated. :!:
update: a dealer in Uk write me just now that the original reference is [Ref. Code: ASK-13383365K], very expensive!!!
but no other info on compatibility with other versions
Discussion Starter · #10 ·
tire 115/70R16
studs/PCD 5x105
wheel 6.5J x 16"
bore 56,6
offset 41
This is only an up :lol:
No tires specialist can help me on topic?
Thank you very much
Discussion Starter · #13 ·
DiscoPanda said:
Buy a wheel with the right spec in the link and you'll be all set
http://www.wheel-size.com/size/opel/astra/2016/
Thanks for your help, but mentioned site doesn't include "space saver steel wheel" :cry:
I need info for elevator too: the standard type doesn't fit with Astra K due to a binary on bottom?
Discussion Starter · #15 ·
DiscoPanda said:
There is nothing special about a space saver wheel. So long as the specification matches the web link it will be fine.
Thanks once again :)
But, i didn't found 115/70R16 fit ...
Are you able to write me where is it? :?:
1 - 15 of 15 Posts
