is anyone else finding their heaters take an age to heat up ? ( 136 diesel )
also i have the dual climate and the volume of air being pushed towards the feet is very poor to compared to all cars ive had including the kadjur loan car i just gave back - even when car is up to temps and heaters on hot with fan on strong just to feet theres hardly any warm air flow towards the feet ,, centre vents and screen recieve the normal type volume of hot air you would expect when you select those areas but in mine to see if the heaters are even set to feet i almost need to reach down a hand to find the pitiful breeze of warm air that comes out centrally - just annoying as i usually have heaters set to toast feet and a window open when i drive
also does anyone else find the centre vents emit a whistling noise if not selected as a source of heat ? ,, cant turn my fan up to 3 lights without a noise that sounds like the kettle is starting to boil
just to see if anyone else finds these heater issues in case its normal or can be fixed
thanks - skool
ps - thank god for the heated seats on cold mornings and the warmed steering wheel we can all huddle around
thanks - skool
