post 26 shows it clearly how 2
www.astrakforums.co.uk
Headlight Bulb Clips
I got the actual clip from my local scrappy, but can't for the life of me figure out how to put on
Yeah I went in naive and buggered it. Can't get clip back in at all now, chuffing hell.I cut & pasted it from @Valer link above^
Pull the clip up (Blue)
the clip follows the grooves (Red) and expands (Green) to allow the bulb to be removed.
Sadly, I dont think I'm able to fit LEDs, would be illegal/fail MOTI fitted these today absolutely awesome LEDs
KATUR H7 LED Headlight Bulb, 80W 16000LM 6000K Cool White 400% Brightness Super Bright 360 Degree Adjustable Beam Angle H7 Headlight Bulb Conversion Kit IP65 Waterproof, Pack of 2 : Amazon.co.uk: Automotive
Buy KATUR H7 LED Headlight Bulb, 80W 16000LM 6000K Cool White 400% Brightness Super Bright 360 Degree Adjustable Beam Angle H7 Headlight Bulb Conversion Kit IP65 Waterproof, Pack of 2 at Amazon UK. Free delivery on eligible orders.www.amazon.co.uk
Stick with it you'll get there eventually, I'm sure. Lesson learnt, I bet you don't do it with the other side.Yeah I went in naive and buggered it. Can't get clip back in at all now, chuffing hell.
The clips are a pain. I found it easier to pull the clips open from the bottom whilst leaving the top clipped in. Just get the clip over the bulb and picnh the bottoms of the clips back in... Worked for me after ages of trying and failing!Yeah I went in naive and buggered it. Can't get clip back in at all now, chuffing hell.
I gave up on it in the end... Might just return these bulbs and go down to Halfords , buy a set of them and then let them fit it. It's really between struggling for hours or get overpriced for a few bulbs...Stick with it you'll get there eventually, I'm sure. Lesson learnt, I bet you don't do it with the other side.
I found them a bit tricky the first time I changed mine, too. Once you've got it, they're easy enough. Changing the drl bulbs on an Astra J were far worse, due to access issues.
They're is a knack to them, once you've done one, it gets easier. Maybe try in the light when you next get chance.I gave up on it in the end... Might just return these bulbs and go down to Halfords , buy a set of them and then let them fit it. It's really between struggling for hours or get overpriced for a few bulbs...
Just in process off cutting out the seal... Well the cap and I'll just add a little sealant!so how you stop water getting in
Ahh right... Think these need the fans so wouldn't want to block those reallyif you would of got f2 the dust cap just about fits
Ended up buying and having these fittedThere is a knack to them, o
I think the only way you'll get white is to use LEDs unfortunately. But hopefully those will be better at night the the standard halogensEnded up buying and having these fitted
Ill send a photo in soon but they're pretty yellow and disappointing still sadly 🙃
I saw the ones @mikejtownsend posted and they looked super white but they were too bright for what I neededI think the only way you'll get white is to use LEDs unfortunately. But hopefully those will be better at night the the standard halogens
