Contemplating doing this. Anybody got any experience from having done it themselves?
On the older cars Maldonado, don't get the main wire colour/tracers confused. coz there is a Yellow with a Grey tracer for the Fog light and a Grey with a Yellow tracer for the N/S brake light. The Violet with a White tracer is the feed for the High-Level brake light which is what you are supposed to splice into.Maldonado said:The color of the brake cable is actually meant to be white-purple for older than 11/2019 cars and yellow-grey for newer models according to instructions
Very good advice Crunchy which I would whole-heartedly endorse. I tend to cut the wire I intend to splice into, add the extra wire, solder the connection then finish off with at least one layer of heatshrink tubing. Crimping (good quality ones, using the correct pliers) would also be a decent way to go.Crunchynut said:Update from me after a problem
I was getting intermittent dash warnings about bulb failure, even though bulbs were fine and sometimes worked normally.
I also got warnings when no trailer fitted - made me think CAN was being scrambled.
So, I soldered the appropriate wire to the CAN cable rather than rely on the scotch lock, and it seems ok now.
If you are fitting from scratch then I would solder rather than use scotch locks (disconnect -ve battery lead first).
The first thing that came to mind was to ask if you have a power tailgate ? Just clutching at straws really as I noticed on my old 1400 (with keyless ign. and a power tailgate) that when the trailer was connected, the power release wouldn't work off either the keyfob or the button on the drivers door. The only way you could open it was to operate the button above the reg. plate. I guess this will be controlled through the CAN network so mebbe some sensors going u/s ?Well, this has turned into a right PITA. I keep getting CAN related problems despite having soldered every connection possible (with battery disconnected so I haven’t fried anything) and it’s driving me mad.
Having worked fine for a while (so I know it is connected correctly) I’m now getting a fault whereby with boot open, everything works fine, but if I shut the boot then I get error signals on the trailer and random information displays about faults. Go figure! Does boot closure put the trailer module into a different mode or something?
Any thoughts?
Hi CrunchySo, I bit the bullet and bought a Brink detachable towbar and fitted it yesterday. Saved £200 on the fitted price.
For those who will take confidence from a little more detail, the commentary below covers what I found.
Electrics:-
Internal electrics are for another day. Watch this space …..
I don't believe anyone makes a kit with male/female adapter plugs for the K to avoid having to splice in any wiring. The vehicle specific kits do take into account parking sensors and cut them out if you're towing which AFAIK the bypass relays do not. If your car hasn't got them fitted, I suppose a bypass relay would do the job perfectly, though you will still have to splice into some existing wiring. One of the members on here (don't think he's around anymore) used a bypass kit on his car HERE and posted a lot of info re: his fitting of it that may help you @John Carson ?Is there an easy just plug it in kit for the wiring or must I fit a canbus bypass relay thingy? (7 pin system is all that required) I have wired those on my H and a Zafira but it was a while ago.
John
Thanks ShakyI don't believe anyone makes a kit with male/female adapter plugs for the K to avoid having to splice in any wiring. The vehicle specific kits do take into account parking sensors and cut them out if you're towing which AFAIK the bypass relays do not. If your car hasn't got them fitted, I suppose a bypass relay would do the job perfectly, though you will still have to splice into some existing wiring. One of the members on here (don't think he's around anymore) used a bypass kit on his car HERE and posted a lot of info re: his fitting of it that may help you @John Carson ?
I have the Brink Diagonal Detachable on mine but it's an ST, not a HB so I don't suppose pics would help you of mine - sorry.
Towing Centres dot com (also known as Towone) Have the Brink Diagonal detachable, with bypass Electrics for just over £302.Thanks Shaky
I'm in the really early stages of selecting/purchasing a towbar, but want to have it done (Fitted by myself) by 31st August.
PF Jones would deliver a Witter detachable with universal 7 pin kit (With bypass) for £356. Vehicle specific kit = £456
AFAIK it lets the car know you're towing summat and sets the towing driving profile up and also lets the CAN network know to turn off sensors,fog light etc but that is a guess on my part admittedly. There is no programming needed on the Astra K, thankfully so it's basically almost the same as fitting a bypass relay. I.E. just splicing a few wires in, although with you not having sensors fitted, you would have to run the CAN pickup wire right to the front of the car unless there is another module at the rear somewhere that has the correct CAN wiring in place.I've a 2019 1.4T Griffin, it doesn't have parking sensors. What does the vehicle specific kit do that's different to a bypass relay Shaky? I'm assuming it's designed not to cause any canbus issues and the electronics are built into the 7 pin socket itself? Having fitted bypass issues without issue before (Albeit on an H and a Zafira of the same vintage) I'd be tempted to save myself £100 and use a bypass relay.
I would have said yes, seeing as the dropdown box (I presume you've selected in that image) states "with bypass" 🤷♂️ but again, that's a guess.I'm not sure if the bypass relay is included with the Universal 7 pin kit, picture attached, what do you think?
Hope any of this helpsThanks all
I looked and looked but all I was being offered was Enganches Aragon towbars, so getting frustrated and needing to get things moving I've just ordered the Witter Vertical with bypass electrics from PF Jones.Towing Centres dot com (also known as Towone) Have the Brink Diagonal detachable, with bypass Electrics for just over £302.
In the first instance I just need to get it bolted on then at least I can pull my motorbike trailer and the lights of the car are still visible!There is no programming needed on the Astra K, thankfully so it's basically almost the same as fitting a bypass relay. I.E. just splicing a few wires in, although with you not having sensors fitted, you would have to run the CAN pickup wire right to the front of the car unless there is another module at the rear somewhere that has the correct CAN wiring in place.
Thanks for taking the time, no doubt when everything arrives I'll be back here asking for more advice. Thanks again for nowHope any of this helps![]()
I've never wired a bypass setup @John Carson so I can't help you on that. The last towbar I fitted was to my Combo Van and that had a "plug'n'play" wiring kit as it had no CAN whatsoever on it.Last time I wired a bypass relay I just connected a 12V power supply to the bypass relay (Probably live when car powered up, I'll figure that out) separate indicator connections left and right, one side light (As the side/brake are common and reading through this thread quickly I believe the K is the same) Don't think I bothered with the fog as neither of my trailers have any ... I think! I'm hoping the K is the same although things may have moved on.
Not sure what you mean by a CAN pickup Shaky, this worries me![]()
No problem bud ask away, there'll always be someone here to assist.Thanks for taking the time, no doubt when everything arrives I'll be back here asking for more advice. Thanks again for now![]()
I would agree whole-heartedly with @Crunchynut comment on the soldering. Either that or a good-quality ratchet-type crimper but soldering + heatshrink would be my preferred optionMy one big piece of advice is to solder your wire splices rather than use scotch locks.
