Really hitting a wall with this one
Changed my rocker, pcv valve, fuel injector seals, spark plugs, the lot
I have a misfire on cylinder 1, was originally cylinder 2 but to rule out the potential cause being wiring switched them around
Why is it I cannot find fuel injectors for this car anywhere? I recently spoke to a guy who told me I could buy d16 fuel injectors as opposed to b16, but they’re slightly shorter in length, wider and a different spray end
I have found some from a chevy Cruze cars which seem to look like they’ll fit, but not sure
the part numbers I have for these injectors are non existent in true motor world unless a direct replacement from Vauxhall at ÂŁ306 each; 55505592
where are the Astra know it alls when I really need one
