61 - 80 of 111 Posts
NIGHTCD said:
Please see pictures from EPC
The bigest instruments at the left and right are static..
it is more partnumbers for more clusters :)
LOL
So the only part of the instrument that differs from petrol to diesel and from KPH to MPH is still analog.
That sounds very illogical.
Hello everybody,
I have the Cluster from the Insignia B, all is ok but i can`t leran on the TPMS on this Cluster. The Insignia have an automatic learning TPMS and the Astra an manuall learning.
@Pepe who have you solved the problem?
Discussion Starter · #66 ·
I dont have the Astra anymore and I did not changed my tyres when I had the cluster fitted.
If you cant program them with the cluster but they did show up with the correct values on the 'old' tyres then you have 2 options:
1: get them programmed manually by someone with GDS2 software.
2: fit the 'old' cluster and program with that one as you were used to (to be sure dont drive with that cluster installed), when done reinstall digital cluster and drive happily ever after.
Astradriver1983 said:
After i switch the Winter Tires to the Summer Tires i can Learn it on with GDS2 on.
Ok thats for me new.
I have a Tool for it to learn the Tires on the Car.
Yes, you must initiate the learning by GDS2 and then use your TPMS learning tool
Thanks, Yesterday i see it in GDS2.
And a other Question:
The Oil Pressiore Display don´t work on the Left side from the Cluster.
Is that possible to switch it to another one?
I see in the Cluster from the Insignia (wher was the Display before) that is another Display Information.
gmprog said:
NIGHTCD said:
gmprog said:
we can help you program remotely
you need an interface OBDLink MX (els27),
Are you able to change Oil Temperature gauge or make it work?
have a photo of the back panel?
Hi, it not the best picture.
do you need another i can remove it from the car and take a photo
Product Circuit component Computer hardware Gas Electronic component
PS: i have one newer too for an Astra K 2020
The new cluster for Astra K with white needles and Navi Pro support. Will this cluster be able to retrofit without the Navi Pro, steering wheel buttons and extensive wiring and programming?
