Long time lurker, first time poster
Has anyone else had a problem with the USB port in the center armrest. I've checked the fuse and anything obvious. It seems that the USB port itself is the problem.
A connected device does not take a charge (tried multiple device and USB cables), I will try a powered USB hub later to see if that helps at all. Perhaps the data pins are still fine.
Just thought I'd leave this here in case anyone else was having issues. I was booked in for a fix this morning but there was a mixup (they hadn't properly booked it in) so now I have to go back next Monday :roll:
I will post back here when I have a solution / more info.
Edit: Sorry I should have been more clear, data transfer doesn't work either. USB port is defective
