Hello all,
I have in the past posted about issues with my infotainment unit, it started to flicker, sometimes would show blank and usually rights itself after a short time typically 5 minutes. I had decided to buy a second hand unit after reading the many posts on the cost new, also a company that can repair for £400 odd, I cannot possibly afford that, but as I know there must be many out there including on this site that have similar issues, the different answers I have had seem to contradict each other. There seems to be belief that just a particular year 2016 was affected and maybe just a run covering a few months, mine was certainly one being an Astra cdti sri 1598 registered September. So I am ok with the fact that Vauxhall had a bad batch of screens and for whatever reason there wasn't a recall, perhaps it took some time for the units to fail I bought my car just 2 years ago and the unit failed about 18 months from then! S o I have been weighing up the options and it didn't seem a bad idea to buy a second hand one which I did on ebay after all it was from a scrapped astra, it arrived and when I removed mine from the car all seemed identical from the front but hey one of the sockets on the rear was different on the 2nd hand one, in any case if I had removed the unit first then checked the serial no of mine and made sure the ebay sellers item serial number was the same I would be sure, so my fault there. I am sending it back with full apologies but the point is there are lots available just now on ebay but reference is made on some that their units for sale are for astra 2016 to 2019, this is a bit misleading as clearly in my case that is not so, as there are more that one type, I am at a loss now as I have scrutinised all photos on each of the sellers and all of them show 2 sockets one being the same and has a micro usb embedded in it, the other one is about an inch wide, mine has the second socket only about half inch wide, in some cases as in mine another socket is visible on the rear as on mine but its not being used, I s there anyone out there that has had a successful outcome on changing a dud unit without having to rob a bank to pay for one, also Im not sure if the units are plug and play or will need coding as of course thats another cost, would appreciate any meaningful answers as without being disrespectful, the last time I posted about this I got bombarded with all sorts of claims and advice, thanks in advance if you can help.
