1 - 10 of 10 Posts
Astra 1.6 CDTi Design Ecoflex 110ps eco warrior!
Does anybody run the "Eco" tyre pressures of 300kpa which is 43.5psi? Does it affect handling or anything? What do you all run at?
32 all round for ours,it's not a diesel but i like to keep my back painfree and all my teeth intact ;)
so i wouldn't dream of setting them that high
Reactions: Boroboy
I dread to think how harsh and uncomfortable 43psi would be,I have found after 5 years with my ST that 32 front 30 rear is the best compromise.fuel consumption is still good.
Reactions: Boroboy
WOW that’s high ! Max I did on my 1.6t was 38 once , steering was light , grip not so good and ride quality deteriorated. Reset to 34 all round and perfect for me.
I do understand if you have 4/5 people on board with luggage to set them higher but 43 is far too high.
i lowered my tyre pressure down to about 35 all around and mine mpg gone down,not sure if its the colder weather but i cannot see that
That can be right Chris , when I pumped my k tyres up to 38 I did notice over the week better mpg .Steering lighter but ride quality poor so lowered back to 34. Not a night & day difference in mpg but def an improvement . Same with a lot of my old cars , higher psi higher mpg but stiffer ride.
When I had 17's, I ran them at 32psi all round. Now on 16's, have around 33psi all round. Expect up to a 3psi variation between summer & winter tyre pressures. Put the 16's on for comfort, greater & cheaper tyre choice, not looks:ROFLMAO:
Discussion Starter · #9 ·
Automotive tire Motor vehicle Automotive design Vehicle Vehicle door
Here is mine, wondering if I'll get more MPG if I put up to Eco pressures, but as said above 43.5psi seems a high amount to put in. Normally stick 34psi front and 32 rear on mine.
I regularly run at about 34/35 all round on my 1.4t (245/45/17). Set them, when I first had the car to the eco setting of 39, appalling noisy/hard ride on the hateful Bridgestone Turanzas.
1 - 10 of 10 Posts
