Well done ! Nothing more satisfying than a cheap fix.I think I've fixed the issue.
I have marked it as red on the attached photo. That clip had came loose and was not connected. I've connected it and the Eml has went off.
Hopefully that's it sorted and fixed and no idea how that had happened.
Thanks. I wonder how long it was loose for or how it even came off.That's one of the connections from the pcv system i was on about,
fingers crossed you'll now see an improvement after the fuel trims get back somewhere close to ok.
Thanks Dave. Everyone been nothing but helpful on here.Well done ! Nothing more satisfying than a cheap fix.
No idea mate. I'm not sure of the name of clip that had come undone that I marked red in the photo. However more worryingly how did it come undone as it on solid now.I had a 13 plate 1.4t meriva that started to have PCV issues. Its really common on the 1.4t engines. I am not sure what much has changed between that engine and the engine that is in the 1.4t astra k. There is a guy in the USA that offers a "fix kit" on the chev cruise as it has the same engine. In the states the 1.4t has way more PCV issues than here, I wonder if its the lower octane fuel or the fact that towns are so far apart so do tons more milage.
