Is there a 12v outlet fitted?
D Deeps · Registered Joined Dec 29, 2015 · 86 Posts Discussion Starter · #1 · Feb 20, 2016 Only show this user Is there a 12v outlet fitted?
S sebati · Registered Joined Jan 11, 2016 · 74 Posts #3 · Feb 20, 2016 Only show this user JJ-Yorks said: yes Click to expand... Where is this?
P Paulch · Registered Joined Jan 18, 2016 · 856 Posts #4 · Feb 20, 2016 Only show this user sebati said: JJ-Yorks said: yes Click to expand... Where is this? Click to expand... Hi Mine is next to the hand brake. Cheers Paul
D Deeps · Registered Joined Dec 29, 2015 · 86 Posts Discussion Starter · #6 · Feb 21, 2016 Only show this user JJ-Yorks said: yes Click to expand... Thank you.
joe.bloggs1 · Registered Joined Feb 16, 2016 · 92 Posts #7 · Feb 21, 2016 Only show this user Is there one in the boot?
C cornishtaz · Registered Joined Sep 12, 2015 · 1,130 Posts #8 · Feb 21, 2016 Only show this user Unfortunately not but should be easy enough to add one as the battery is located under the boot carpet so running power will be easy.
D Deeps · Registered Joined Dec 29, 2015 · 86 Posts Discussion Starter · #9 · Feb 21, 2016 Only show this user Is it in the same place when a normal handbrake is fitted?
D Deeps · Registered Joined Dec 29, 2015 · 86 Posts Discussion Starter · #11 · Feb 21, 2016 Only show this user Thanks Marc.
