41 - 60 of 81 Posts
Discussion Starter · #47 ·
hi myukjob85
My dealer did this modification but i hear the rattle again on cold start. Should I need to contact dealer?
Do you still hear the rattle at startup again? Mines is done in april 2021. What engine oil do you use?
Its only at startup not when running or something.
If ut rattle again after the gasket install that means that unfortunately the guides was broken before the installation so you will need to replace the cam chain and all accessories
That's not what I am thinking. It was good for a month of 3 after modification (no rattle). My car is still in warranty for this repair they did in april. I will complain again. And yes mines is filled with Opel original 0w20
Hi, today finaly gasket is in opel garage.They call me and ask me , if I am sure that want to mount this gasket .
I need help about this gasket numer - 55515025 is for new revision of tensioner number - 55505562 or this gasket is prefer to use on old version of tensioner ?
I dont know what to tell on my delar and they wait me
Do it important to change rocker cover gasket ?
Is it possible to change later when engine and gearbox is mount ?
On Monday I will go to my delar.
Sorry for late reply. So rocker cover gasket 55571587 , tensioner revised 55505562 , injectors washers 55590468 , tensioner gasket 55515025.
I tell to my dealer to add gasket for tensioner. Now I want ask what motor oil to use. I know that is prefer to use 0W20 may be for rattle noise , but after added new tensioner and gasket , do you think that 0W20 is best choice ?
After installed new tensioner and gasket rattle noise will be fixed, can you advice which motor oil will be best.
Which oil is required for which engine is on multi post on the site but here it is again
Introduction of new specification engine oil OV0401547 low viscosity 0W20
We would like to make you aware of an immediate change to the engine oil that must be used in conjunction with the latest generations of engines in our passenger car range.
The low viscosity 0W20 oil meets the newly developed Opel Specification OV0401547 and is now available in several pack sizes.
This engine oil is now mandatory on all engines listed below.
Part Number Product Description Pack Size
95528693 0W20 OV0401547 1 L
95528694 0W20 OV0401547 5 L
Engines RPO Code
B10XE, D10XE L5Q
B10XFL, D10XFL, F10XFL, F10XFT LE1
MY18 and later
B14XFL, D14XFL, F14XFL, F14XFT LE2
MY18 and later
B15XFL,D15XFL,B15XFT,D15XFT LFV
D16DTJ,D16DTL, D16DTH LVL (Only EURO 6.d)
D16DTI LXO
B16DTC, B16DTL LVM
B16DTC, B16DTE LWQ
B16DTU LWV
CSS prime 40: F12SHL, F12SHT, F12SHT LIH
CSS 45: F14SHT L3T
CSS 50V: F15DVH LXD
CSS 50V: F20Dxx LSQ
In the meantime it is permissible to continue using Dexos2 on Diesel Engines, and Dexos1 Gen2 5w30 on Petrol Engines
with the exception of the New CSS Family Engines.
OV0401547 low viscosity 0W20 oil must be used on the CSS engines in order to provide adequate lubrication of the wet timing belt system.
Dexos is not permitted.
Reactions: Boroboy
You haven't posted any info on your car that i can see,
so first question is the car actually a MY 18 or later ?
If you post the VIN i'll see if i can find which emission standard the car is
It comes up as rpo code NE4 - EMISSION-SYSTEM EEC 14
so not 6d which is rpo code NCV
Discussion Starter · #60 ·
I do think is a better choice but needs to be dexos 2. I used 0w20 liqui moly 6600 witch is meeting the dexos 2 equivalent. The engine running smoothly and less vibration on idle almost can not feel it.
41 - 60 of 81 Posts
